06-02-2010 04:45 AM
I am installing PCI-6503, and it does not pop up in Device and Interafces section of MAX
as described on page 1 of this document: http://digital.ni.com/manuals.nsf/websearch/E7E3A35E9C873774862575E000586D07
The board is reported as working correctly by Windows XP SP3 Device Manager.
I can also see the board in PXI System section of MAX, and if I hit troubleshoot button it says "Device OK".
Here is how I installed the board:
- installed DAQmx (NIDAQ910f0.exe)
- shut down my PC installed the board
- powered on the PC
- checked if the board is in Win XP Device Manager
Any ideas how to fix this? I've already tried to remove the board from my PC and install it again - no change.
Yuriy Olkhovyy
06-03-2010 01:11 AM
Dear Mr. Olkhovyy,
thank you so much for your post on our website. Did you get any pop up that new hardware was found? Is there any sign of uninstalled hardware in the device manager? Can you try another PCI slot? You can also try another PC (not install driver) and see if there is a pop up of new hardware found; then we know the card itself is a life.
06-03-2010 03:31 AM
Hello Martijn,
Everythimg went fine with the card detection by Windows XP - it was successfully registered, and appeared as working correctly in the Device Manager.
Nevertheless the card did not show up in Devices and Interfaces section of MAX.
I've replaced NI DAQ-mx v 9.1 by v8.5 and everything works fine now - I assume the problem has something to do with NI DAQmx v9.1
Yuriy Olkhovyy
06-03-2010 03:43 AM
Dear Mr Olkhovyy,
Thank you for your feedback. DAQmx 9.1 should work with this card. I think something was wrong with the DAQmx installation or the MAX data base. The new installation resolved this problem.
