05-28-2012 07:49 AM
Not sure this is the right board for this subject, but I'm having a problem with my new NI PCI1422 frame-grabber.
I have a Nikon TE2000 microscope with a VDS 1300Q camera , up until a while we used the MU-1500 frame grabber with the camera along with the NIS element 2.2 AR software.
The frame-grabber died so we replace it with the NI PCI1422 after checking that it's compatible. I've assemble the cable according to the pin-out layout I received from NIS and installed the IMAQ 4_6_4 along with the frame-grabber.
I also installed the NIS 3.1 AR along with the -all line in order to install the VDS 1300 camera, but whenever I try to run the the NIS I get an error saying "missing niini32.dll" then the NIS starts and it seems to work fine , but whenever I try to capture a picture I'm having a problem with the exposure and the pictures seems to Jump (see attached) , the live feed seems fine but the capture pic isn't the same as the feed.
I can't figure if the problem is in missing dll or the assembled cable or the NIS itself.
Dan
05-29-2012 06:06 PM - last edited on 02-19-2024 11:34 AM by migration-bot
Have you used NI's Measurement & Automation Explorer to configure this camera? Have you dealt with the camera's Camera File yet? When you have a camera, you have to ensure that the camera itself is pointed to a customized camera file that configures to its settings. It looks like the images you're getting are due to the camera acquiring in a different tap configuration than the software is expecting. You simply need to make a camera file that is configured to the correct tap configuration.
This document tells you more about camera files. https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI74CAG&l=en-US
The NI Camera File Generator (https://www.ni.com/en/support/documentation/supplemental/19/creating-a-camera-file-using-the-ni-came...) is free software that allows you to create a custom camera file, including setting up the tap configuration. Do you have tap configuration information from your manufacturer?
