I want to be able, from the keyboard, type in a bit stream 19 bits long, and have each bit of my stream sent out only when the clock transitions. This will happen only once. I will use the internal clock of the board. The bit stream will be written to 1 LINE only (in prevoius questions I used the phrase "channel" which I think is incorrect). An example of a LINE is say DIOA0. DIOAO passes one bit at a time as the clock transitions, and passes 19 bits altogether. No handshake, no trigger used or needed. I am using PCI 6534 and LABVIEW 6.0. Fairly new to electronics, if someone could point m
e in the right direction that would be a great help. I looked at BUffered Output Vi, seemed close, not sure how to modify. Any example code anywhere? Believe this question is under the subject of "I/O Pattern Generation" but not sure. Also what does "(Un)strobbed" mean and is it relevant for this?
