Digital I/O
non-repetitive Pattern generation PCI-6534, LABVIEW 6.0, no trigger, no handshake, serial bit stream output to one LINE, each bit outputed with board's internal clock
I want to be able, from the keyboard, type in a bit stream 19 bits long, and have each bit of my stream sent out only when the clock transitions. This will happen only once. I will use the internal clock of the board. The bit stream will be written to 1 LINE only (in prevoius questions I used the phrase "channel" which I think is incorrect). An example of a LINE is say DIOA0. DIOAO passes one bit at a time as the clock transitions, and passes 19 bits altogether. No handshake, no trigger used or needed. I am using PCI 6534 and LABVIEW 6.0. Fairly new to electronics, if someone could point m
e in the right direction that would be a great help. I looked at BUffered Output Vi, seemed close, not sure how to modify. Any example code anywhere? Believe this question is under the subject of "I/O Pattern Generation" but not sure. Also what does "(Un)strobbed" mean and is it relevant for this?
(3,541 Views)
Nate you may wish to look at the answers for the other answers posted to your similar questions on the Dev Exchange.
(3,541 Views)
