From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
I have two simple question in PCI-6527. Because of my poor electricity knowledge, I need some help. 1. PCI-6527 use what kind of chip :it use 8255pp, E series or 653x, I can not find it in labview measurement manual. If I want to see some example for application of PCI-6527. Where directory should I look for/
2. What is the difference between non-isolated power and isolated power? In which case, I should use non-isolated power or isolated power.
The PCI-6527 board uses an internal FPGA digital circuitry to generate the digital I/O lines. It's not the 8255 chip. What the product manual means by isolated power is that the digital lines are opto decoupled, meaning the grounds will be completely isolated one from the other. You can find examples for that board at C:\Program Files\National Instruments\Labview 6\examples\daq\652x. Hope this helps. Filipe
