I am using HSDIO APi's to generate waveform in PXIe 6555 card. Is there any way to control data generation rate? Example : Clock rate is 800 Hz and data should be generated only at the 4th clock pulse every time (Pulse 4,8,16..) Can it be done using any kind of triggers or events available for HSDIO?
