08-09-2017 06:38 AM
I am using a myRIO to output fast switching TTL signals to control a laser system. I used to do this using a DAQ but due to the conditions of the experiment we needed something faster so the myRIO with its fpga board was the choice we made. However, since the myRIO only supports up to 3.3V on its DIO ports I was thinking of using a level shifting circuit but the simple ones to build wouldnt be good enough as for the experiment the propagation delay cannot be higher than 100us. Basically, I want to know if anyone has used a levelshifting circuit or IC that can do this and if so what do you recommend?
Thank you,
Jaafar Harari
08-09-2017 07:43 AM
JaafarHarari wrote: I was thinking of using a level shifting circuit but the simple ones to build wouldnt be good enough as for the experiment the propagation delay cannot be higher than 100us.
100us is an eternity! I have used the SN74LVCC4245A with little problems over the years (the problem I have had we concluded were due to a power supply not regulating properly). The specification claims a rise and fall time in the 10ns range.
08-09-2017 07:48 AM
Looks great but do you perhaps know if there is a DIP format of the same chip? as I am only allowed into a teaching lab and surface mount soldering isn't really on the menu 😛
Cheers,
Jaafar Harari
08-09-2017 08:35 AM
Not that specific chip. But you can use my link and go up a level to the "Logic - Translators, Level Shifters" and do whatever filtering you want to find a part that will work for you. There is a mounting type filter, set that to Through Hole if you need a DIP.
08-17-2017 06:22 AM
For many modern ICs there are no DIP versions. But there are adaptor mounts where you can solder a SMT device and have a DIP pin arrangement. But you have to do the soldering yourself. It depends on the pin spacing of the IC whether you can solder it with a very fine solder tip (down to 1mm spacing approx) or if you have to use special solder techniques (also with a soldering iron) for smaller spacing.
