10-03-2007 08:03 AM
10-17-2007 07:57 AM
Hi Erik,
You can use different ports from different processes or threads. If you try to use a port in use you will get an error saying that the digital lines are reserved. So there is no way that two tasks control the same resource simultaneously. If you want to lock a resource before starting the task, you can use the daqmx control task.vi.
DAQmx resource availability check deals with similar questions.
