Digital I/O
max current of NI's 6351 per channel or all ports?
I'm reading the spec for the PCIe-6351 and it has 24 mA max listed for P0.0...7.  Is that per pin or for all 8 outputs?
Thank you,
Ron
(1,537 Views)
Accepted by topic author mysticfree
The following specs are per-channel (NI calls out explicitly if the spec changes based on the number of active channels or if it is shared).
Santhosh
Soliton Technologies
(1,510 Views)
