06-05-2008 02:35 AM
06-05-2008 06:51 AM
You should have posted this question to the instrument control board.
You are also missing some information in your post. What is the make and model of the USB GPIB controller you are using. I'm guessing it is an NI since you posted here. Judging by the small snippet of code, you had been using an HP/Agilent controller before. If that is the case, you will need to make extensive modifications to your program to use the driver from NI and not the old one. The commands to use an Agilent or an NI controller are not the same.
06-05-2008 09:59 PM
06-05-2008 10:47 PM
