Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Digital I/O
installation of ni-daqmx-runtime-core using NI Package Manager 23.0.0
I'm facing a problem running the installation of ni-daqmx-runtime-core using the following batch script which is run as administrator:
start /wait NIPackageManager23.0.0.exe --prevent-reboot
"c:\Program Files\National Instruments\NI Package Manager\nipkg.exe" install ni-daqmx-runtime-core --accept-eulas -y
It works fine on my virtual machine, but is does NOT work on my local machine, stating the following error message "Unable to locate package 'ni-daqmx-runtime-core' with a compatible version and architecture". Both machines are 64 bit system and use Windows 10, version 22H2. I already tried to specify the package version to  ni-daqmx-runtime-core_23.0.0.49366-0+f214_windows_x64 (using the following line "install ni-daqmx-runtime-core:windows_x64_23.0.0.49366-0+f214"), but it did not solve the problem. Additionaly I tried using PackageManager version 23.3.0, but this also did not work out.
I would be pleased to receive any help.
(3,287 Views)
Problem occurs only when using an online installation, using a local package feed works. When going to the online feed's url https://download.ni.com/support/nipkg/products/ni-package-manager/released there are no packages found. Anyone an idea whether the package url has changed or some other advice.
(3,248 Views)
Accepted by topic author alfdghoadhsfglnkafl
Rafael, when you are trying to use "online feed", I assume you are trying to connect to a ni.com feed, and if so, did you register an ni.com feed that has that package?
Example:
nipkg.exe feed-add --name=mydaquri https://download.ni.com/support/nipkg/products/ni-d/ni-daqmx/23.0/released
nipkg.exe update
Scott Richardson
https://testeract.com
(3,238 Views)
Hi Scott,
I very much appreciate your advice, it helped me to resolve the issue.
Best regards
Rafael
(3,228 Views)
