Digital I/O
increase rate of pattern generation 653x
Hello everybody,
I tried to use the example NIDAQ/Examples/VisualC/Do/DoSingleBuffPatternGen653x.c to output digital data from a group of two ports, with internal timing.
The problem is that when I choose to decrease the time between two digital outputs under 0,2 ms I am said that "the given clock rate is not supported by the associated counter channel or I/O channel "
I know that the 653x device is capable to generate pattern with a high speed rate but how ?
I simply need to read a file of data and output with time interval like 2 microseconds...
Can you help me ?
Nepenthes
(4,578 Views)
Did you try
iPgTB = 1  // Timebase = 1us
iReqInt = 2  // Pulse will be iReqInt * iPgTB = 2us
(4,555 Views)
yes, it works ! but I don't understand : if I choose iPgTB = 2 and iReqInt = 1, which corresponds to a rate of 10 microseconds ( > 2 microseconds !) I have an error ! So can I trust to the rate I am defining ?
Nepenthes
(4,528 Views)
could you post the error you have?
(4,519 Views)
the error is -10011 : "the analog input scan is too fast for the number of channels and the channel clock rate; or the given clock rate is not supported by the associated counter channel or I/O channel "
Nepenthes
(4,522 Views)
Try this code:
(4,514 Views)
Hi !
I've tried your code... same error when i take iPgTB =3 and iReqInt = 1 but works when taking iPgTB= 2 and iReqInt= 1 like in my code !
Nepenthes
(4,509 Views)
