ok, thanks,
but that's what I thought, I have a problem->
in calling the following function:
"DAQmxWriteDigitalLines(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,samps,0)" in order to put an I/O at 5V, the board answer me :"Reserved parameter must be NULL"
the reserved parameter is the last one in the list
do you know what I have to do?
this function is declared:
function DAQmxWriteDigitalLines(taskHandle: TASKHANDLE;
numSampsPerChan: INT32;
autoStart: BOOL32;
timeout: FLOAT64;
dataLayout: UINT32;
writeArray: array of UINT8;
var sampsPerChanWritten: int32;
var reserved: bool32): INT32; cdecl;{$IFDEF WIN32} stdcall;{$ENDIF} external Fichier_Dll;
did anybody try to use the dll with a soft wrtitten in delphi??
regards,
Nicolas L.
