03-07-2006 11:40 AM
03-08-2006 09:23 AM
nyc,
The installation of DAQmx 8 may solve your problem, and version 8 is certainly the recommended driver for that device. However, it probably should have worked with 7.4 as well. Before you install DAQmx 8, shut down and remove the 6503. Next, install DAQmx, and shut down the PC. Now, install the 6503 and re-boot. Windows should now detect the card. Select the option to allow windows to find and install the driver for the device. Once this completes, try to test the device again in MAX. If it doesn't pass the self test, let me know what the error is. Hopefully the upgrade does the trick though.
LA
03-08-2006 09:55 AM
03-09-2006 11:12 AM
03-09-2006 12:47 PM - edited 03-09-2006 12:47 PM
Michael,
I used a different NI DIO card at my previous job.
The GUI aka TestPanels for commanding the card through MAX seemed to be different and was more intuitive.
The current GUI won't let me set the ports on the PCI-6503 to be outputs. Is there any documentation on how to do this? It shouldn't be that hard. I know that I can do this through the DAQmx GUI but I should also be able to do this through DAQ traditional as well.
Message Edited by nyc on 03-09-2006 01:49 PM
03-10-2006 10:46 AM - edited 03-10-2006 10:46 AM
Message Edited by Michael P on 03-10-2006 10:47 AM
03-10-2006 11:53 AM
03-10-2006 03:13 PM
