ni.com is currently experiencing slowness/issues due to ongoing maintenance.
Support teams are actively working on the soonest resolution.
06-08-2011 07:35 PM
I am using a motor controller that communicates through a serial port at 9600 baud. I use the Labview to generate the specific command that we want the motor to execute, (speed, direction, time etc.) which is a short string like "/1J97E0M\r " Each character in the command specifies something for the motor to do.
Is it possible to calculate how many times per second a command like this can be sent with data rate at 9600 baud? For example, is it possible to know how many bits the string "/1J97E0M\r" is? Can this value be divided into 9600 to calculate the maximum rate that command strings can be sent to the controller? Is it that simple?
06-08-2011 10:07 PM - edited 06-08-2011 10:10 PM
The number of bits is obvious but it's not that simple. The motor has to interpret the data, act on it, etc. This response time/max data rate would be specified by the vendor.
And please post similar questions to the instrument control board. This has nothing to do with NI's digital I/O products.
06-09-2011 09:57 AM
Thanks, Dennis. I posted it here because I thought this board was for I/O, but, if it is for NI I/O exclusively, then, I will only post questions about NI products here.
