Digital I/O
how can i use a ring buffer to do digital input at 0.5 MB/sec
I am supposed to capture input coming at ~ 0.5 MB/sec. I have 6533 DI card to do so. I was trying to set up a ring buffer (like the buffer in IMAQ) to use with this high data rate but it is not coming along. I get the first 300 samples (16-bit/samples) only and the rest is not filled up. I get this by making library calls using the C functions to do the acquisition since using the high level LabVIEW vi's would not acquire anything. So I was wondering if somebody has tried this before and would tell me the steps or if there is an example in LabVIEW that does something similar (I tried the Pattern I/O, Handshaking etc that use double buffering but I dont seem to get them to work). Any hints would be appreciated. Thanks
(3,187 Views)
Hello fady,
What kind of errors are you getting? Have you tried any of the LabVIEW shipping examples for this card with your application? Are you using a C example that downloads with DAQ? There is no on-board memory with the 6533 and the transfer rate is system dependent. Could this be a factor? I'm including a link to a document on NI's website that might have some useful information for you:
http://zone.ni.com/devzone/conceptd.nsf/webmain/E5A26C86E0C32E4886256BE20050E9E3?opendocument#1
(3,173 Views)
