09-07-2012 03:58 PM
I am new to NI.
I need to make a system with embeded controls I am considering using FPGA.
I need to know, if the application program is stored in non volatile memory, as otherwise after a power failure, the application
software would have to be downloaded again? Is this the case in FPGA?
09-07-2012 04:38 PM
On the FPGA I am using (a 7811R) the program is stored in non-volatile memory and should work fine after a restart.
09-08-2012 09:18 AM
FPGA isn't exactly a program. It is manipulating gates to perform a specific task. The definition of the gates does not change with a power outage.
Also, you should compile your code into a bit file. The bit file is then used to program the FPGA. The process of downloading the bit file is really fast, so I doubt it is something to really worry about (depending on your application).
09-10-2012 11:59 AM
