if I create a digital output task, one channel for each line, dev2/port0/line3 (for example), then use Digital 1D bool Nchan 1Sample, what is the state of the other 7 lines of that port?
PCI-6723 using LabVIEW 8.6
Reason I ask is that I recently damaged the board due to at least one and possibly more mistakes.
I wrote to one digital output as above, my UUT read this input and turned on its own digital outputs (9V), I then made a call to read digital inputs:
Then that wonderful smell announced to the office there was an issue.
interestingly despite there being a hole in the top of the large NEC chip on the board, and loss of counter and digital channel functions, it still passed resets and self-tests in max.
Can I be sure that if I use one line for output the other 7 will stay as input (high impedance) or did setting one line to output mean the other lines where also set to output (low impedance) so that when the UUT turned on its outputs, bad things happened?
I realize the digital inputs are designed for 5V, but thought I was okay at 9 due to the 11V channel to earth working voltage limit.
