Hi, I am trying to hook up some relays to my digital I/O of my M series DAQ card. The relay requires a 5V signal to switch, but has an internal resistance of 250 ohms. The maximum output current of the daq card i believe is 24mA, which would work, but if the resistance varies at all the relay current draw may exceed 24mA. What is the best way to do this?
Would this work:
If I supply 5V, using an external power supply, to the source of the relay and connect the sink of the relay to a digital output from my DAQ card. The digital output would be held at 5V until I needed it to be switched, at which point I would change the Digital out to zero and so all of the current would be supplied from my external power supply. My question with this method is: if I specify a digital channel to be used as output, what is the maximum current that can flow into that channel?
Thanks!
Sunny
