03-10-2011 11:17 PM
As part of my project i want to measure strain at 8 different locations on a specimen. Can anyone suggest me a device that can take 8 strain gages data to the computer via usb. And for this purpose can i use SCC-SG24 modules because those modules are there in our lab, i know SG24 modules are used for full bridge circuits, but for my project my strain gages are connected in quarter bridge, is it possible to measure data in quarter bridge mode using SG24 modules
03-11-2011 12:52 PM - edited 03-11-2011 12:53 PM
03-12-2011 08:12 AM
Hi Roman,
we have NI DAQ pad 6015 in our lab. So which one will you recommend NI 9236 or SG24 modules. cost is also is important criteria for us because we might use this equipment once in a year. what is your opinion on SCXI 1520 does it meet all our requirements.
03-14-2011 12:46 PM
I think your best options is to go with a USB cDAQ 9174 chassis, and a NI 9235 or NI 9236 module to put in it.
03-18-2011 06:01 PM
in the specifactions of cDAQ9174 it is mentioned "Run up to seven I/O tasks simultaneously". what does it mean. After seeing that statement i got a doubht because i want to measure 8 strain gaguges using NI 9236.
03-23-2011 03:18 PM
In the specifactions of cDAQ9174 it is mentioned that it can "Run up to seven I/O tasks simultaneously". what does it mean. After seeing that statement i got a doubht because i want to measure 8 strain gaguges using NI 9236.
03-24-2011 01:28 PM
Tasks are different then channels. A task can run many channels as long as they are on the same sampling rate. The cDAQ 9174 has 3 Analog Input timers, 1 Anolog Output Timer, 1 Digital In, 1 Digital Out and 1 counter. But as long as put all of those strain gauges in the same task with the same sampling rate, you should be fine. I hope this helps.
03-25-2011 11:21 AM
How to do shunt calibration in NI 9236 module
03-28-2011 01:10 PM
Katakam,
In the example finder there is a VI under the folder Hardware Input and Output>>Analog Measurements>>Strain>>Cont Acq Strain Samples (with Calibration).vi that will help you to understand and use shunt calibration with the NI-9236. This should meet your needs for doing a shunt calibration with your device.
