From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Digital I/O
connecting to REQ signal generated internally by PCI-DIO-32HS in pattern I/O mode
Hi...
i need to connect to the REQ signal generated internally by PCI-DIO-32HS in pattern I/O mode , but i can't get any signal form pin# 2 or pin# 9 of the card, i wonder if there should be do some parameter seeting or something?Thank you!!
(3,153 Views)
Alvin,
It would be a good idea to try an example program first just to make sure that you can see the signal. A good example to try is posted under NI Developer Zone>>Development Library>>Measurement Hardware>>Digital Input/Output>>Pattern Input/Output >>Changing the Pulse Width of an Internally-Generated REQ Signal.
If you still do not see the signal after trying this example, then I would suggest to contact National Instruments Support (ni.com/support).
Good luck!
(3,153 Views)
