Hi Ryan,
This solution can only work for 50Mhz and 25Mhz. It may have trouble for 40Mhz and 20Mhz.
I plan to use an external clock source such as PXI 5406. But some considerations are needed:
1. When the pattern is gonna to change the frequency, PXI 6552 will send out a event as a trigger to PXI 5406. This is to inform PXI 5406. I think this shall have no problem. right?
2. Sending trigger to PXI 5406 can be very fast. But how fast is it for PXI 5406 from receiving the trigger to the time the new frequency is stable? This can be done by hardware or need software?
I am not sure if NI ever did this experiment or not.
Thanks and regards,
AhGang
