Want to control digital output USB6215 with button. The active time presetable from control, like 5.2 seconds
Hopefully simple solution
-Stefan
it is a simple solution..have you looked at the NI shipped examples? Goto Help>Find Examples...>Hardware Input and Output>Daqmx>, if your button is external hardware...you need "Analog Input or Digital Input" to acquire the signal..if not, then software controlled...this all needs to be sent to >Digital Output.
note: the Requirements box will indicate what NI devices you can run with these examples...
