09-21-2009 04:57 PM - edited 09-21-2009 05:02 PM
I'm tyring to use one of the digital input lines on my PIC-6143 to go to the "enable" connection on the "write to measurement file" vi. I have two PCI-6143 boards doing analog signal acquisition of eight channels per board, plus I have one digital DAQ assistant to sample DIO line 2 on one of the cards. Normally I can start/stop recording using a 5V signal to the DIO port several times before I get the error.
Strangely, when I use a simple boolean "Record" button to the enable port of the "write to measurement file" vi, I never get this ADC error no matter how many times I press the button.
I'm including a screen shot of the error.
Chris
Solved! Go to Solution.
09-22-2009 03:39 PM
