Digital I/O
What is the pinout for R1005050 Cable. I need pinout on 50pin side.
I need the pinout on the split side of R1005050 cable (where two 50 pin connector is).
Hiren Patel
(6,964 Views)
Hiren,
You can find the pinout for the R1005050 cable by referencing the PCI-6023E/6024E/6025E User Manual as well as KnowledgeBase 29DIBKYF: What are the pinouts for the R1005050 cable used with the PCI-6025E (or simi.... Best of luck with your application.
Brian Anderson
(6,964 Views)
I also need the same information when connecting the R1005050 Cable to the PXI-6528. It appears to be provided for the PXI-6508 per the User Manual in a table on page 18:(Figure 3.2).
Figure 3.2Figure 3.2
(https://www.ni.com/docs/en-US/bundle/pci-dio-96-pxi-6508-pci-6503-feature/resource/374938b.pdf#page=...)
Where is the same information provided for the  PXI-6528 module?
(4,253 Views)
