Digital I/O
What are the min and max input voltages and currents of PXI-6221 M Series Multifunction cards?
I want to know the followings for the PXI-6221 M Series Multifunction card?
       -  For AO: Minimum output voltage, Minimum output current, Maximum output voltage, Maximum ouput current?
       -  For AI: Minimum imput voltage, Minimum input current, Maximum input voltage, Maximum imput current?
       -  For DIOs: Minimum imput voltage, Minimum input current, Maximum input voltage, Maximum imput current?
       -  For Counters/Timers: Minimum imput voltage, Minimum input current, Maximum input voltage, Maximum imput current?
(3,983 Views)
Have you considered reading the specifications?
On the product page for each (go to Products and Services and use the search field), there is a specifications tab that has a link to the actual document. After reading that, post back with specific questions.
(3,979 Views)
Hello KizKas,
Thank you for posting to the NI Forums! The best way to find a particular specification for a product is to go to ni.com and search for that product's model number (i.e. 6511). By clicking on the link for your particular product, you will be directed to the product page. There you will see a tab called Specifications. You can click on Detailed Specifications under this tab and access the specs of the device. Also, you can click on the Resource Tab and access all manauls associated with the device. Have a great day!
Message Edited by Margaret F. on 02-23-2009 11:28 AM
Margaret Barrett
Digital Multimeters and LCR Meters
(3,946 Views)
