Digital I/O
Wait instrcution timeout
I'm using PXI6552 with scripting. I use the wait instrcution with scripttrigger (Digital edge).
I would like to know if there is a possibility to configure a timeout for the Wait instruction because in the case the trigger never happen, I don't want to block my script
Thank you
JPV
(4,179 Views)
Hi JPV,
Thank for using National Instruments discussion forums.
If you have questions about scripting,please refer to the API Community: LabVIEW Scripting Main Board. I think you will get the best help there.
(4,162 Views)
My question is not about LabVIEW scripting but about HSDIO scripting, so I'm not sure The API Community: LabVIEW Scripting Main Board is the right place to post my question.
could you confirm?
Thank you
JPV
(4,154 Views)
Hi JPV,
You can configure the niHSDIO Wait Until Done VI or C function to give your script a programmatic timeout parameter, which will cause your program to error and exit gracefully in the event that a hardware script trigger is not detected within the timeout period specified by your code.  I hope this helps!
Kyle A.
Senior Applications Engineer
(4,134 Views)
This is what I currently plan to do and I wanted to be sure it was the good method
Thank you.
(4,123 Views)
