Digital I/O
Vi running so slow to write/Read a Digital I/O on cDAQ-9185
Hi Kevin,
I seperated DAQmx Write, start task and clear, each function in VI and i timed only the call DAQmx Write the same problem.
I tried to update the frimware of cDAQ, to connect the cDAQ directly with another PC (Windows 7) and i still have the same issue.
Message 11 of 12
(701 Views)
You're still measuring the overhead of all the config operations because you're feeding in a Global channel.  Use the technique you showed in msg #5 where you explicitly configure and start the task *before* you start measuring execution time.
-Kevin P
Message 12 of 12
(694 Views)
