Digital I/O
Using multiple NI9403 for Hardware Timed Input and Output Applications on a cDAQ
Hello everybody,
I am developing a control application using a cDAQ-9189 chassis and Python (nidaqmx). My goal is to run simultaneous, hardware-timed Digital Input (DI) and Digital Output (DO) tasks (e.g., generating output patterns while sampling incoming digital edges, both at <10 kHz).
I am currently using an NI 9403 module, which has led to some confusion regarding its hardware timing capabilities in a cDAQ environment.
Documentation Discrepancy: The official NI 9403 specifications state: "In a CompactDAQ chassis, you can use the NI-9403 only as a static (software-timed) digital I/O module. You cannot use these modules to route timing or triggering signals."
However, in my testing, I found that I can actually run a hardware-timed continuous task (using AcquisitionType.CONTINUOUS). The limitation is that I can only run one direction at a time.
My Proposed Solution: To bypass this single direction bottleneck, I am considering installing two separate NI 9403 modules in the same cDAQ-9189 chassis:
  • Module 1: Configured entirely for hardware-timed Digital Input
  • Module 2: Configured entirely for hardware-timed Digital Output
My Questions for the Community:
  1. Is using two NI 9403 modules in this manner a valid and recommended workaround for achieving concurrent hardware-timed DI and DO in a cDAQ chassis?
  2. Are there any hidden limits with the cDAQ-9189's Correlated DIO engines that would prevent these two modules from streaming simultaneously at my target rates?
  3. From a system design perspective, would it be vastly superior to simply replace the 9403 with a parallel digital module like the NI 9401 to natively support concurrent multi-engine tasks, or is the dual-9403 approach perfectly stable?
Any insights into the best practices for this architecture would be greatly appreciated!
Best Regards,
CB
(509 Views)
Accepted by carmenberry
What you are seeing is all documented in Digital I/O Considerations for C Series and TestScale Devices
To answer your question:
1. Using two NI-9403 for separate directions is a supported configuration.
2. cDAQ has dedicated digital task for input and output, as shown in Timing Considerations for C Series Devices
Only one hardware-timed digital input task and one hardware-timed digital output task per CompactDAQ chassis at a given time is supported,
3. The main difference is the update rate. NI-9403 only supports up to 7us (about 143kHz) whereas NI-9401 supports MHz level. It shouldn't matter much for your use case of 10kHz.
(446 Views)
