10-05-2007 09:21 AM
10-08-2007 07:01 PM
Hi Charles Hamm,
In order to repeatedly generate the same block of data, you must set ND_PATTERN_GENERATION_LOOP_ENABLE in the Set_DAQ_Device_Info function to ND_ON. There are a couple restrictions when looping from the onboard memory. If you are using 8-bit data, the buffer size must be a multiple of 4. If you are using 16-bit data, the buffer size must be an even number. There are no restrictions for 32-bit data.
This information can be found in the NI 653x User Manual for Traditional NI-DAQ at the top of page 2-12.
Please post if you have any questions. Have a great day!
