I've got the timed loop working with the 6509 after using DAQmx Create Timing Source (Digital Change Detection).vi. I've been able to send data using the timed loop at the rates I need.
I'm now trying to create a runtime executable (LV 8.0) so that I can run this on a stand-alone computer. I created a project, then the executable and it runs, but the Timed Loop never seems to start. Why would the executable not run, yet the development environment works fine?
I tried creating a simpler version of the program, I wired an indicator to the loop index, and created a boolean-typed shift register that I perform an "not" operation on for each iteration; this is connected to an LED indicator. WIth a 10 Hz (or any other pulse rate) the development environment runs fine, but when I compile and try to run the code with the runtime engine (again on the development machine) it appears as if the loop is hung.
Message Edited by Phillip Brooks on 02-01-2007 01:20 PM
Message Edited by Phillip Brooks on 02-01-2007 01:21 PM
