Digital I/O
USB845x single DIO pulse with specific length
Hi, I have integrated the USB845x using python ctypes to use the DIO. I want to output a single pulse with the length of 10 microsecond. However, I am able to do it with the minimum length of 250 microsecond using the C API. Maybe there is a overhead of using python to access the NI USB845x. Is there a specific code to make sure it pulse maximum of 10 microsecond?
Here is my code for the python DIO pulse:
portNum = 0
    lineNum = 0
    writeData = 1
    offData = 0
    check_error(ni845x_dll.ni845xDioWriteLine(dev_handle,portNum, lineNum, writeData))
    # time.sleep(0.00001)
    start = time.perf_counter()
    while (time.perf_counter() - start) < 10e-6:
        pass
    check_error(ni845x_dll.ni845xDioWriteLine(dev_handle,portNum, lineNum, offData))
I have tried time.sleep and even run it without both type of delay. The smallest will still be 200+ microsecond.
Thanks in advanced.
(1,199 Views)
Accepted by topic author RudyTS
You are hitting a limit of using Windows/software timing.  What you really need is a counter output (if using a DAQ) or Function Generator that can output a pulse.  If on a hardware budget, I would probably just get a Raspberry Pi Pico and program it to do my pulse.  Even a Pi5 might be able to do it (I have not played around with one yet, so I do not know what kind of timing is possible on it).
(1,168 Views)
portNum = 0
    lineNum = 0
    writeData = 1
    offData = 0
        pass
Thanks in advanced.
You're using the wrong hardware for the job. 845x DIO are supposed to be used for non-time restricted operations like setting some relays or mode signals on your DUT along with I2C/SPI communication. You need a M or X-series DAQ at least to generate the 10us pulse.
Santhosh
Soliton Technologies
(1,164 Views)
