Hello dwillis,
Even though our Multifunction USB DAQ devices may not be suitable for your application, perhaps the following system will work for you.
The
SCXI 1600 is basically a USB DAQ board that installs into an SCXI chassis. This means that you communicate with the SCXI chassis through USB and your digitizer is in the chassis as well.
The
SCXI 1162HV is a 32-Channel Optically Isolated 240 VAC/VDC Digital Input Module. Take a look at the
Data Sheet to see if this module will meet your specifications. The 1600 should work with other SCXI modules as well, so feel free to look at other module options.
All that is left is the chassis. The
SCXI 1000 is a 4 slot chassis.
I hope this helps!
Eric
DE For Life!
