Digital I/O
USB-6525
In a first time I want to control an USB-6525 by labview. I want to creat 3 switch that control relays as if switch1 is down relay1 is open, switch2 is close so relay is close
I can control switch by using DAQ assistant (Labview8.5), I can select wich relay I want to open/close but I don't know how to connect it with a switch to not have to enter in the DAQ assistant.
In a second time I would like to control them by timers but I want firstly to understand how does it work with simple switch
Thank you
Kind regards
Ps: I'm french so, sorry for mistakes
Message 1 of 10
(9,109 Views)
Just take your 3 front panel Booleans and wire them to the Build Array function. Pass the array to the DAQ Assistant/DAQmx Write.
Message 2 of 10
(9,107 Views)
Accepted by Rodolphe_ber
Thank you for answering me 🙂
I will try that
Kind regards
Rodolphe
Message 3 of 10
(9,097 Views)
Thanks you, it work 🙂
Now I would like to check my input lvls:
If i have 5V  on my input P0.0, i would like to light on a led (on labview) on output P0.0
If i have 5V  on my input P0.7, i would like to light on a led on output P0.7
I think I need something like the "build array" but i don't find it
Kind regards
Rodolphe B.
Message 4 of 10
(9,092 Views)
Hi Rodolphe B.,
There is something I misunderstood : P0.0 is an input or an output?
David S.| Certified LabVIEW Associate Developer
National Instruments France
Message 5 of 10
(9,083 Views)
I will try to re-explain:
I use a USB-6525 I have some signals on my inputs, and I want to switch-on LED when there is a signal
If there is a signal on the 1st input, I want to switch on  LED1
If there is a signal on the 2nd input, I want to switch on  LED2
My question is how to make the link between the DAQ assistant and my LED on labview?
I want to use LED as a control: when my process is finish it send a signal and i can see when it's finish
Thanks you for answering me ,
Kind regards
Rodolphe B.
Message 6 of 10
(9,081 Views)
Probably, we could switch in French...
Ainsi, vous voulez donc allumer une LED lorsque vous recevez un signal numérique (0 ou 1) sur 1 entrée numérique matériel. En revanche, la LED ne doit pas être allumer que sur 0 ou sur 1 mais tant que vous recevez des données. Est ce cela?
Message 7 of 10
(9,077 Views)
Bonjour,
Désole pour l'explication confuse en anglais
Je pense que vous avez bien compris mon problème
J'aimerait que des que le 6525 reçoive un signal sur ces entrée, j'allume une led sous labview ce qui me permettrait de contrôler si oui ou non j'ai un signal sur l'entrée
Mon but final est de faire un banc de test automatiser et j'aimerait afin de géré la partie mécanique, avoir des signaux de contrôles (étape 1 finie , étape 2 finie ...) par exemple des que la pièce est en butée, on émet un signal sur l'entrée 1 du 6525 et je peut ensuite enchaîner sur l'étape suivante
Merci pour votre aide & pour celle de votre collaborateur précédant
Je n'ai malheureusement pas d'expérience dans labview donc je patauge un peu dans la semoule 🙂
Cordialement
Rodolphe B.
Message 8 of 10
(9,072 Views)
Pourriez vous créer un autre forum sur la partie française et poster le lien de ce nouveau forum sur ce forum afin de garder la logique?
Cordialement
Message 9 of 10
(9,067 Views)
Why continue in french?! Do you french people as usual think you are the world language and every one else SHOULD understand french? Dont you think other can have use to understand National Instruments hardware?
Message 10 of 10
(3,991 Views)
