07-14-2020 12:10 PM
This is a relatively straightforward and simple question. I just wanted to ensure that the HYT-271 Humidity Sensor would work with the USB-6509 board I have? There are many posts regarding its compatibility with the myRio-1900 which is a board I'm more familiar with.
Thank you!
07-14-2020 12:43 PM
No. The HYT-271 talks over I2C. The USB-6509 is STATIC DIO (ie software timed). It will not work with I2C. I would recommend getting a USB-8451 or USB-8452, which are devices specifically for talking over I2C and/or SPI buses.
07-14-2020 12:47 PM
Hm okay thank you. Do you think there are humidity sensors that are able to be configured with this board?
07-14-2020 06:26 PM
I doubt there are any sensors that will just give you a static parallel value. So no. You might find some that output a voltage you can read with a simple DAQ (Analog Input).
