07-04-2006 08:45 AM
07-06-2006 01:55 AM
Unfortunately, there is no supported way to use the USB-6501 under Windows 98. The USB-6501 can use either the NI-DAQmx Base driver or NI-DAQmx 7.4 or later. The NI-DAQmx Base driver only works on Windows 2000 and XP. Because support for Windows 98 and ME were dropped from the NI-DAQmx driver after version 7.1. The only solution for this is to upgrade your operating system.
Regards
