Digital I/O
USB-6501 output structure
Figure 4 of the NI USB-6501 OEM User Guide shows a port IO circuit.  Rp is populated with a 4.7 kOhm pull up resistor.  The documentation states an output can be configured as push-pull.  Does that indicate that actual micropin on the USB microcontroller, as shown in Figure 3 block diagram, will be configured as push-pull, basically overriding the pull up / open drain circuit?  Is there circuit diagram of what an actual port pad looks like?  That is, when push-pull, does the port pad have a dual transistor circuit connected to it?
Reviewing the PCB, I observe a low side transistor on all the pins with the 4.7 kOhm pull up resistor, Rp.
Thank you.
Message 1 of 8
(5,437 Views)
Hi Tony,
You have to software configure your digital output port so that it becomes a push-pull output. To do this, there are several ways outlined in this KB:
http://digital.ni.com/public.nsf/allkb/D9B4018C3E540CE4862570F30068C0DB?OpenDocument
This forum post also highlights how you can change the output type in software:
http://forums.ni.com/t5/Multifunction-DAQ/USB-6501-DIO-Push-Pull-Configuration/td-p/1151965
Once you set this, the DAQ device will automatically change its settings in order to operate as a push- pull device. No, there is not an explicit circuit drawing of the proprietary hardware for the port pad. Figure 5 of the manual shows the basic port configuration for the different output types.
Message 2 of 8
(5,404 Views)
Hi Roxana.  Thank you  for the information.  When I try the links you provide, they do not work.  Maybe I am doing something in error when I try to execute them.
A question regarding your statement below regarding the port pin circuit.  Acknowledged you can not show the circuit detail.  However, based on Fig  6 of the User's Guide (you state this below), the port is open drain with the pull up resistor.  Hence a change in software then reconfigures the port pin to actually have the structure of a push pull transistor circuit?  I'm trying to wrap my head around the pull up resistor now in parallel with high side FET (I suspect).  As I look at the board I see a low side transistor and the 4.7 kohm resistor.  I am thinking about the output of the microcontroller connected to that circuit.
Thank you.
tony
Message 3 of 8
(5,333 Views)
Hi Tony,
This link should work. I've added the title so you can at least search it as well
How Do I Configure My NI Device to Be Open-Drain (Open Collector) or Push-Pull (Active Drive)?: http://digital.ni.com/public.nsf/websearch/D9B4018C3E540CE4862570F30068C0DB?OpenDocument
Title of Forum:
I can try and gather more info on what exactly the software does when we're configuring the push-pull configuration.
Daniel Parrott
Software Product Marketing - Data Management & LabVIEW
Message 4 of 8
(5,303 Views)
Hi Tony,
It looks like you may have found a documentation issue. We're still trying to pursue this to get to the bottom of it, but I'll let you know once we do!
Daniel Parrott
Message 5 of 8
(5,211 Views)
Thank you for the information.  The link to the note works.  The basis of my original question is to understand correctly this output structure of the USB-6501; hence, apply the part correctly.
Message 6 of 8
(5,193 Views)
Hi Tony,
I did get some clarification on this. In Figure 6 of the 6501 User Manual the circuit depicted acts like an open drain and will weakly pull up to 5V. When the Push/Pull configuration is configured, the DAQmx driver basically adds another resistor into the circuit that drives the voltage. Unfortunately that's as much info as I can provide, but I hope that helps!
Daniel Parrott
Message 7 of 8
(5,140 Views)
Interesting.  Thanks for digging into this.  Not how I think of push-pull, but all info is good info.  My application I bufffer the USB-6501 digital out as a conservative approach to the design.
tony
Message 8 of 8
(5,131 Views)
