Digital I/O
USB-6501 not working in Matlab with Windows 7 64bit
I am using the USB-6501 to control an attenuator.  I have written the driver to work with WinXP, but now that I am trying to use it on Win 7 64 bit, it is causing an error.  At first it complained about not having C++ studio 2008 (we had 2010), and I have fixed that.  Now it seems to be complaining about the DLL.  I talked to NI, and they think that we need a different DLL for Win 7 64 bit.
I did find the newer version DLL (nicaiu.dll) in the System32 directory from when I installed the updated driver for Win 7 64bit and copied over to my local directory.  I also copied the new nidaqmx.h file over to my local directory.  I am still getting the following error from MatLab:
Loading nicaiu.dll...
??? Error using ==> loadlibrary at 365
Failed to preprocess the input file.
 Output from preprocessor is:'cl' is not recognized as an internal or external command,
operable program or batch file.
Error in ==> USB_6501_driver at 38
        funclist = loadlibrary('nicaiu.dll','nidaqmx.h','alias','myni');
Any help would be greatly appreciated.
Steve
Message 1 of 12
(3,845 Views)
Hi Steve,
It sounds like your program or one of the libraries it is using cannot find the 'cl' command. The 'cl' command is part of Microsoft Visual C++. (Also a part of the Windows SDK, Windows Driver Kit, etc.)
Brad
Brad Keryan
NI R&D
Message 2 of 12
(3,842 Views)
Hey Brad,
I have loaded up the proper C++ compilier - in this case is was asking for Visual C++ 2008.  I have instlled it and selected it in MatLab, but I'm still getting the error.  It seems like it is looking for .cpp file, but can't find it.  The nocpp variable is set.  Works fine on XP, but not Win7 64 - Very frustrating.
Steve
Message 3 of 12
(3,834 Views)
Hi Steve,
Does that mean you have solved the "'cl' is not recognized as an internal or external command..." error? If you are now getting a different error, I recommend posting the error text so that someone who knows Matlab (I do not) can help you.
Brad
Brad Keryan
NI R&D
Message 4 of 12
(3,831 Views)
Hey Brad,
No, I am still getting the same error from my original post.  Nothing has changed.  I was just pointing out that I already checked the C compilier, upgraded to most recent version of the driver, and set matLab to use Visual C++ 2008 as required by the driver.  There still seems to be a library issue.  I stepped through the code and the nocpp variable was set which causes it to drop into the code generating the error below.  One thing that is different between the XP and Win7 computers is that on the XP machine I am running MatLab 2009a and on the Win7, we are running MatLab2010b.  I sure wish one of the NI guys would have an answer to this post.  Here's the error again:
Steve
Message 5 of 12
(3,819 Views)
Hi Steve,
nicaiu.dll doesn't invoke the "cl" command. Based on your error message, I think that Matlab's loadlibrary command invokes "cl /E" in order to run the NIDAQmx.h file through the C preprocessor, but it can't find the cl.exe executable, so it never even gets to the point where it can run any NI-DAQmx code.
Brad Keryan
NI R&D
Brad Keryan
NI R&D
Message 6 of 12
(3,816 Views)
Hey Brad,
Yeah, it does seem to be in the preprocessor code section when it failes.  I didn't know what "CL" represented, but that is interesting that you suggest it is an .exe file.  I will search the XP machine to see if that file is present.  I may go back and step the code on the XP machine to see what it does in the section that generates the error.  It does seem to create some temporary files, but maybe you're right that it can't find the cl.exe (I thought cl was a variable) and so it can't continue loading up the NI-DAQmx code.  Thanks for the tip...I'll check it out...
Cheers,
Steve
Message 7 of 12
(3,812 Views)
Steve,
Have you had a chance to look for the CL file on the XP machine or check the behavior of the working set up at the breaking point the new machine is seeing?
From going through the above, it does sound like there is some trouble finding and running the cl.exe file which is keeping the program from running further operations.
A quick web-search for "Matlab cl.exe" gave me several results for other people having trouble (with various other drivers or programs) with CL going missing, so it may not be a driver specific issue.
Timothy
Timothy S.
PXI & VXI Platform Product Support Engineer
Message 8 of 12
(3,758 Views)
Hi Tim,
I went and check to see if the cl.exe file was installed on the Win7 64 system, and it was found in the Visual C++ directory where I would expect it.  I went back and stepped though the code on the working system and the failed system, and the problems seems to be when MatLab goes to make a call to the operating system.  The variable comes back empty and that is why is droping into the failure message.  Here's the code whre it fails:
if (~nocpp)
        [res,ccout]=system(preprocess_command);
        if (res==1)
            error('MATLAB:loadlibrary:cppfailure',...
                  'Failed to preprocess the input file.\n Output from preprocessor is:%s',ccout);
        end
        if (regexpi(ccout,'warning|error','once') )
            warning('MATLAB:loadlibrary:cppoutput','Message from C preprocessor:\n%s',ccout);
        end
    end
Steve
Message 9 of 12
(3,739 Views)
Hi Steve,
It does not appear from your code that this is an error involving the USB driver or any function calls for DAQmx, therefore this forum may not be the best resource to find a solution to this issue since it doesn't seem to be rooted in the driver functions.
Justin
Justin
Product Support Engineer - Conditioned Measurements
Message 10 of 12
(3,711 Views)
