From 11:00 PM CDT Friday, Nov 8 - 2:30 PM CDT Saturday, Nov 9, ni.com will undergo system upgrades that may result in temporary service interruption.
06-21-2019 02:14 AM
I am trying to input Digital 12bit data(5V TTL) into USB-6366(BNC Model).
According to specification, PFI 0-11 can be utilized. However connector shape are BNC and another ports. It is not convenient. If P0.0 - P0.7 and PFI 8-11 could be utilized, it would be great. Is it possible to do such connection ?
Solved! Go to Solution.
06-23-2019 07:38 PM
Hi KevWhat
You only can use 2 additional BNC terminal using User 1 and User 2 connectors.
USB-6366 BNC has 24 digital I/O lines (3 port = 8 lines). The Digital and Timing I/O BNC connectors are only routed Port 1(P1.0 - P1.7). If you connect User 1 and User 2 to any terminals in Screw terminals, They are routed User Access BNC connectors.
06-23-2019 08:21 PM
Hi Ueno,
Thank you for giving your comment.
Bottom line may be "Screw terminals can not utilize as Digital Input". I expect.
But I don't understand the detail what you explained for Language Barrier.
-> Could you explain the detail? You mean USER1,USER2 BNC ports can be utilized as Digital Input(like D8,D9?).
Best,
06-23-2019 09:17 PM
I am sorry for the lack of explanation.
Yes, USER1,USER2 BNC ports can be utilized as Digital Input. For example, User 1 screw terminal connects P0.0 screw terminal, User 1 BNC terminal will be P0.0.
If you don't use User 1 and User 2 terminals, you only can use Port 0 (P0.0 - P0.7) and Port 2 (P2.0 - P2.7) in the screw terminals.
06-23-2019 10:39 PM
I understood USER1, USER2 BNC are "Blank Ports", thus we can assign another signal on screw terminal. It make sense.
-> It looks, I can utilize these ports as Digital 11bit input. I will try.
06-23-2019 10:58 PM
It's my pleasure. If you have any questions, please post again.
