Digital I/O
USB-6366 Digitail input ports
I am trying to input Digital 12bit data(5V TTL) into USB-6366(BNC Model).
According to specification, PFI 0-11 can be utilized. However connector shape are BNC and another ports. It is not convenient. If P0.0 - P0.7 and PFI 8-11 could be utilized, it would be great. Is it possible to do such connection ?
(3,032 Views)
Hi KevWhat
You only can use 2 additional BNC terminal using User 1 and User 2 connectors.
USB-6366 BNC has 24 digital I/O lines (3 port = 8 lines).  The Digital and Timing I/O BNC connectors are only routed Port 1(P1.0 - P1.7). If you connect User 1 and User 2 to any terminals in Screw terminals, They are routed User Access BNC connectors.
(2,998 Views)
Hi Ueno,
Thank you for giving your comment.
Bottom line may be "Screw terminals can not utilize as Digital Input". I expect.
But I don't understand the detail what you explained for Language Barrier.
-> Could you explain the detail? You mean USER1,USER2 BNC ports can be utilized as Digital Input(like D8,D9?).
Best,
(2,992 Views)
I am sorry for the lack of explanation.
Yes, USER1,USER2 BNC ports can be utilized as Digital Input. For example, User 1 screw terminal connects P0.0 screw terminal, User 1 BNC terminal will be P0.0.
If you don't use User 1 and User 2 terminals, you only can use Port 0 (P0.0 - P0.7) and Port 2 (P2.0 - P2.7) in the screw terminals.
(2,988 Views)
Accepted by KevWhat
I understood USER1, USER2 BNC are "Blank Ports", thus we can assign another signal on screw terminal. It make sense.
-> It looks, I can utilize these ports as Digital 11bit input. I will try.
(2,983 Views)
It's my pleasure. If you have any questions, please post again.
(2,978 Views)
