Digital I/O
USB-6289 Setting Digital output signals
I am using a USB-6289. I am writing a CVI application which uses this device. I need to set the Digital I/O pins as outputs. In the CVI application I know that I can create these tasks with Tools->Create/Edit DAQmx Tasks. It created this:
int32 CreateDAQTaskInProject(TaskHandle *taskOut1)
 int32 DAQmxError = DAQmxSuccess;
    TaskHandle taskOut;
 DAQmxErrChk(DAQmxCreateTask("DAQTaskInProject", &taskOut));
 DAQmxErrChk(DAQmxCreateDOChan(taskOut, "USB-6289/port0",
  "DigitalOut", DAQmx_Val_ChanForAllLines));
 DAQmxErrChk(DAQmxSetChanAttribute(taskOut, "DigitalOut", DAQmx_DO_InvertLines, 0));
    *taskOut1 = taskOut;
Error:
 return DAQmxError;
So this sets it up but doesn't write the data out. My question is what is the command to write the data out?
Also I was wondering if there any example source code which shows how these commands are done? Is there a way to configure the bits individually? I only need to use 5 of these pins as outputs so t would be coll if I could write to only bits D0-D4.
Are there any documents written on these commands and how they are used?
thanks in advance
(3,595 Views)
Accepted by DPearce
A DAQmxWrite writes the data.
Go to Help>Find Examples>Hardware Input and Output>DAQmx>Digital Generation.
If you specify lines instead of a port, you can use however many bits as you want.
First look at the CVI help.
(3,581 Views)
