Hi
As far as I can work out from your post you have 5 power supplies that you want to trigger off the 6008 5V digital lines. You should be able to do this easily.
Regarding Synchronization on the 6008 there is no hardware clock and it is all based on interrupt requests, so no I am afraid you can’t use the Multi-Function-Synch AI-A0.VI.
If you require USB format there is the new USB 6259 M series that will do Synchronization or you can use some thing like a USB 6015,16.
Tim
AE NI UK and Ireland Technical Support
