Online shopping is currently unavailable.
Please contact us for help or try again later.
Digital I/O
USB-6001 how to use?
The wiring to a string seems pretty pointless. What do you expect to do with that? Have you run any examples?
Message 11 of 19
(5,281 Views)
Hi again Dennis,
Well I´m just trying to understand how to simulate an analog measurement taken from the USB6001, and then import to a visualization variable. But it is quite difficult for me.
It's some years since I use labview in school... so I forgot many things.
Message 12 of 19
(5,274 Views)
Then open the example finder and limit the search to the hardware you have. Under Hardware Input and Output there is a DAQmx section.
Message 13 of 19
(5,262 Views)
Hi again,
I have bought the USB6001 and Im doing some tests, adquiring analog measurement I have no problem (upper diagram).
But when I want to inyect some voltage I have some errors (in the diagram below)... ¿Can anyone help me with this simple problem? I am blocked
The examples doesnt help me too much...
Thanx
Message 14 of 19
(5,186 Views)
Wire a physical channel to the appropriate input like you did with the write.
Your VI will only run once. You need a loop. Do not use the run continuous button.
Message 15 of 19
(5,173 Views)
Hi again,
I did what you mentioned and errors disappear, but now the program indicates that the buffer is not enough. I dont know where to set the buffer size, and which is the exact size. I just want to extract 5V for example.
The theme of the loop is controlled, it is an issue that will solve later. I just want to see that the output is activated.
Message 16 of 19
(5,156 Views)
The code makes no sense. You try to generate a 0 Hz signal? Then you tell it to use a waveform for timing, then write only a single sample. If you want to generate a single voltage, get rid of the timing function and just wire a constant to the DAQmx Write.
Message 17 of 19
(5,151 Views)
Ok, there were some mistakes...
I am trying to generate a DC continuous signal, for example 5V. It must be activated untill I stop it.
Which is the configuration of the write module? It must be digital single channel, multiple samples and waveform?
Message 18 of 19
(5,144 Views)
It should be Analog DBL 1Samp like you have now with a scalar connected instead of that waveform as I said. Static voltages do not require the timing function either, as I also said. You can place the DAQmx Write inside a while loop and use a front panel control for the voltage setting. When the loop exits, be sure to write 0 volts before stopping and clearing the task.
Message 19 of 19
(5,134 Views)
