Digital I/O
USB-6001 DAQmx_SampClk_Rate Error
I am trying to digital out a square wave using USB-6001, using python with spyder.
Sorry for the rudimentary problem.
I get an error when I try to use the function about DAQmx_SampClk_Rate on my USB-6001.
Is USB-6001 incompatible with DAQmx_SampClk_Rate?
The version of nidaqmx is 0.7.0.
(693 Views)
Accepted by topic author Emuka
The USB-6001 is a simpler device that doesn't support any kind of sample clock for output.  Only for analog input.   Output has to be software timed (i.e., a tight loop over calls to DAQmx_Write to generate individual sample values).  The effective rate will be relatively slow and much less consistent.
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(663 Views)
USB-6001 Specifications
Surprisingly, USB-6001 actually supports hardware-timed output.
What is the error code reported? Did you configure the sample clock timing? Please attach the code so that we can understand better.
(653 Views)
Thank you for your answer.
I see that the sample clock output function does not exist on the USB-6001.
It may be difficult to control 1ms unit by software, but I will try.
(639 Views)
Sorry for my lack of words.
The error code indicated the following
DaqError: Specified property is not supported by the device or is not applicable to the task.
Property: DAQmx_SampClk_Rate
I see that this was stated in the specification.
I'll take the time to read it again.
(636 Views)
You cannot change this property if you don't configure the sample clock timing by calling DAQmxCfgSampClkTiming.
Check out the shipping example C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage\Cont Acq-Int Clk
(595 Views)
