01-07-2019 12:21 PM
Hello everyone !
I've just bought a NI-9401 for some stuff I'm working on. I'm using Python with this device and I'm having trouble. I spent the last 3 days searching everywhere online and I couldn't seem to find any answers (I'm fairly new to both Python and NI btw).
So here is the thing : I want to test the device by transfering some floats from a digital output to a digital input.
Here is my code so far :
import nidaqmx as ni import numpy as np import matplotlib.pyplot as plt from nidaqmx.constants import (LineGrouping) ## Emission ## fe = 44100 f = 440 T = 0.05 t = np.linspace(0, 0.05, fe*0.05) sig_E = np.sin(f*2*np.pi*t) plt.figure() plt.subplot(211) plt.plot(t, sig_E) plt.title("Signal Emis") plt.tight_layout() with ni.Task() as task: task.do_channels.add_do_chan("cDAQ1Mod1/port0/line0", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES) task.write(sig_E) ## Reception ## with ni.Task() as task: task.di_channels.add_di_chan("cDAQ1Mod1/port0/line4", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES) sig_R = task.read(number_of_samples_per_channel=len(t)) plt.subplot(212) plt.plot(t,sig_R) plt.title("Signal Recu") plt.tight_layout() plt.show()
So it's 5 seconds of a sine at 440 Hz and I want to send it from the DO to the DI (linked with a cable). But the error message I get is that the "write" function can only send boolean samples and obviously I want to send floats.
So how can I send my sine through the digital output (and read it from the digital input)? What are the appropriate functions ?
Thank you in advance for your help.
Best regards.
01-08-2019 04:09 AM
Digital = 2 values (on and off). If you are using a single channel, then you need an analog input and output. Or, you can convert your value into a 8 bit number and write to the entire port and read it back.
01-08-2019 04:45 AM
Wait, are you saying that this card (NI-9401) can only send and read boolean samples ???
01-08-2019 06:24 AM
That is the definition of "Digital".
01-14-2019 04:47 AM - edited 01-14-2019 04:55 AM
Thank you for your answers ! I still might be able to use this card. So now that I know that it can only send en recieve booleans, I tried to send à chirp, made of booleans values, from a DO to a DI. But I can't make it work. Here is my code so far : I create à square signal, with linear frequency modulation, from 220Hz to 2200 Hz, for about 0.02 second, with a sample rate of 40kHz. Then I convert the values of my signals into booleans, whih should make it good for the DIO channels.
import nidaqmx as ni import numpy as np import matplotlib.pyplot as plt from nidaqmx.constants import (LineGrouping) from scipy import signal ## Generation ## fe = 40000 # sample rate T = 0.02 # duration t = np.linspace(0, T, int(fe*T)) # time vector f1 = 220 # freq min f2 = 10*f1 # freq max f = np.linspace(f1,f2,len(t)) # freq vector sig_E = signal.square(f*2*np.pi*t) # chirp for i in range(0,len(sig_E)): if sig_E[i]>0: sig_E[i]=True else: sig_E[i]=False sig_E = [bool(sig_E[i]) for i in range(len(sig_E))] # float2bool plt.figure() plt.subplot(211) plt.plot(t, sig_E) plt.title("Signal Emis") plt.tight_layout() ## Emission ## with ni.Task() as task: cho = task.do_channels.add_do_chan("cDAQ1Mod1/port0/line0", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES) task.timing.cfg_samp_clk_timing(fe) print(task.timing.samp_clk_rate) task.write(sig_E, auto_start=True) ## Reception ## with ni.Task() as task: chi = task.di_channels.add_di_chan("cDAQ1Mod1/port0/line4", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES) task.timing.cfg_samp_clk_timing(fe) sig_R = task.read(number_of_samples_per_channel = len(sig_E)) sig_R = [int(sig_R[i]) for i in range(len(sig_R))] # bool2int plt.subplot(212) plt.plot(t,sig_R) plt.title("Signal Recu") plt.tight_layout() plt.show()
But It doesn't work. My plot shows the signal sent through the DO, but when it comes to the recieved signal by the DI, it's not what I've sent.
I read somewhere on the NI website that to be able to use both DI and DO, I need to use 2 ports. But When I try to create the DI channel by writting "port1/line4" (since I have "port0/line1" for the DO), I have an error message saying that this channel doesn't exist on this hardware. Weird because in the user manual, it's specified that I have to use 2 ports.
Thanks in advance for your answer !
01-14-2019 04:59 AM
