Digital I/O
Trouble with DIO !
Hello everyone !
I've just bought a NI-9401 for some stuff I'm working on. I'm using Python with this device and I'm having trouble. I spent the last 3 days searching everywhere online and I couldn't seem to find any answers (I'm fairly new to both Python and NI btw).
So here is the thing : I want to test the device by transfering some floats from a digital output to a digital input.
Here is my code so far :
import nidaqmx as ni
import numpy as np
import matplotlib.pyplot as plt
from nidaqmx.constants import (LineGrouping)
## Emission ##
fe = 44100
f = 440
T = 0.05
t = np.linspace(0, 0.05, fe*0.05)
sig_E = np.sin(f*2*np.pi*t)
plt.figure()
plt.subplot(211)
plt.plot(t, sig_E)
plt.title("Signal Emis")
plt.tight_layout()
with ni.Task() as task:
    task.do_channels.add_do_chan("cDAQ1Mod1/port0/line0", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES)
    task.write(sig_E)
## Reception ##
    task.di_channels.add_di_chan("cDAQ1Mod1/port0/line4", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES)
    sig_R = task.read(number_of_samples_per_channel=len(t))
    plt.subplot(212)
    plt.plot(t,sig_R)
    plt.title("Signal Recu")
    plt.tight_layout()
    plt.show()
So it's 5 seconds of a sine at 440 Hz and I want to send it from the DO to the DI (linked with a cable). But the error message I get is that the "write" function can only send boolean samples and obviously I want to send floats.
So how can I send my sine through the digital output (and read it from the digital input)? What are the appropriate functions ?
Thank you in advance for your help.
Best regards.
(607 Views)
Digital = 2 values (on and off).  If you are using a single channel, then you need an analog input and output.  Or, you can convert your value into a 8 bit number and write to the entire port and read it back.
(580 Views)
Wait, are you saying that this card (NI-9401) can only send and read boolean samples ???
(577 Views)
That is the definition of "Digital".
(569 Views)
Thank you for your answers ! I still might be able to use this card. So now that I know that it can only send en recieve booleans, I tried to send à chirp, made of booleans values, from a DO to a DI. But I can't make it work. Here is my code so far : I create à square signal, with linear frequency modulation, from 220Hz to 2200 Hz, for about 0.02 second, with a sample rate of 40kHz. Then I convert the values of my signals into booleans,  whih should make it good for the DIO channels.
import numpy as np
from scipy import signal
## Generation ##
fe = 40000        # sample rate
T  = 0.02        # duration
t = np.linspace(0, T, int(fe*T))                                              # time vector
f1 = 220        # freq min
f2 = 10*f1        # freq max
f  = np.linspace(f1,f2,len(t))                                                # freq vector
sig_E = signal.square(f*2*np.pi*t)                                            # chirp
for i in range(0,len(sig_E)):
    if sig_E[i]>0:
        sig_E[i]=True
    else:
        sig_E[i]=False
sig_E = [bool(sig_E[i]) for i in range(len(sig_E))]                             # float2bool
plt.figure()
plt.subplot(211)
plt.plot(t, sig_E)
plt.tight_layout()
## Emission ##
    cho = task.do_channels.add_do_chan("cDAQ1Mod1/port0/line0", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES)
    task.timing.cfg_samp_clk_timing(fe)
    print(task.timing.samp_clk_rate)
    task.write(sig_E, auto_start=True)
## Reception ##
    chi = task.di_channels.add_di_chan("cDAQ1Mod1/port0/line4", line_grouping=LineGrouping.CHAN_FOR_ALL_LINES)
    sig_R = task.read(number_of_samples_per_channel = len(sig_E))
    sig_R = [int(sig_R[i]) for i in range(len(sig_R))]                          # bool2int
plt.subplot(212)
plt.plot(t,sig_R)
plt.tight_layout()
plt.show()
But It doesn't work. My plot shows the signal sent through the DO, but when it comes to the recieved signal by the DI, it's not what I've sent.
I read somewhere on the NI website that to be able to use both DI and DO, I need to use 2 ports. But When I try to create the DI channel by writting "port1/line4" (since I have "port0/line1" for the DO), I have an error message saying that this channel doesn't exist on this hardware. Weird because in the user manual, it's specified that I have to use 2 ports.
Thanks in advance for your answer !
(454 Views)
import numpy as np
## Generation ##
T  = 0.02        # duration
f1 = 220        # freq min
    if sig_E[i]>0:
        sig_E[i]=True
    else:
        sig_E[i]=False
plt.figure()
plt.subplot(211)
plt.plot(t, sig_E)
plt.tight_layout()
## Emission ##
## Reception ##
plt.subplot(212)
plt.plot(t,sig_R)
plt.tight_layout()
plt.show()
(452 Views)
