01-10-2019 04:26 AM
I have a cDAQ 9189 with 8 Slots with NI 9201 as AI and NI 9401 as DI/DO. I want to Transfer analog Signals to a TTL Signal(Output) so as to trigger a data logger.
01-16-2019 02:27 AM
HI himanshu25,
Could you describe it a bit more, what do you mean by:
"I want to Transfer analog Signals to a TTL Signal(Output)"
You want to convert analog signals to digital? Or send out some digital signal based on the analog input?
AmbrusG
01-16-2019 03:08 AM
I want to convert Analog Signals to Digital Signals. I did it in the attached vi but I am not sure of the frequency is same or different.
01-16-2019 04:01 AM
Well I don't see any attached VIs in any of your comments. Could you pleas add it again?
AmbrusG
