Digital I/O
Trigger VI
Hello guys,
                       I want to enable a trigger signal when the input at the Trigger block goes high.I have attached the block diagram.The idea is to enable a trigger when the sine wave output goes positive.But the trigger block doesn't give high output.Please help..Thanks..
(4,774 Views)
Why not just use the Greater Than 0? function?
(4,766 Views)
Thanks for the reply crossrulz and congrats..
If i use a greater than condition,when the sine wave goes positive ,it would give  true value.But when the sine wave again becomes negative,the if condition gives a false.My requirement is when the sine wave goes positive,i should able to generate a square wave continously regardless of the sine wave condition.However,i did this part using an SR latch and a switch.I have attached the block diagram.But the problem now is,when the square wave starts to give output,the sine wave  appears like a stepped function.I have attached that picture as well.Cant,both the generators simultaneously generate waveforms?Is there some changes i have to do with FPGA Clock?
(4,743 Views)
