04-12-2011 06:27 PM
I have written code in LabWindows/CVI that controls our devices with static TTL level BCD outputs, and then read the two TTL feedback lines. Up until now, we utilized the NI-6503, 24 line DIO card and the Legacy DAQ “WriteToDigitalPort” and “ReadFromDigitalLine” commands. e.g.:
WriteToDigitalPort (1, "1", 8, 0, 0x01); //Output BCD 0001 to low bits on Port 1
ReadFromDigitalLine (1, "0", 0, 8, 0, &doneFB1); //Read Done feedback line 1 on Port 0
Each device requires four BCD inputs, so I was able to control two devices per port. We utilize two lines of Port 0 for each devices feedback lines. This allows control of four devices per DIO card. We would like to transition to the USB version of the 24 line DIO (NI-USB-6501), which requires the DAQmx driver. I have updated our version of CVI to allow DAQmx commands, but I’m not sure which of the DAQmx Digital I/O functions would be comparable to the legacy “WriteToDigitalPort” and “ReadFromDigitalLine”. In addition, to be completely honest, the whole “DAQmx Task” thing has me a little confused.
Definitely getting a feeling of “this used to be so simple…”.![]()
Any suggestions would be appreciated.
John
04-13-2011
01:15 PM
- last edited on
09-26-2025
09:38 PM
by
Content Cleaner
Hi John,
Here are some links to some very useful information on how to transition your LabWindows/CVI project from Legacy DAQ to DAQmx. Also, the Example Finder in LabWindows/CVI is a great resource to see how to configure DAQmx calls as well! In LabWindows/CVI, if you go to Help » Find Examples, the Example Finder will open, and you can browse through and see the various examples of how to read and write to a device using DAQmx by going to Hardware Input and Output » DAQmx. From here, there are numerous examples on how to create projects using DAQmx. Hope this helps!
Transitioning from Traditional NI-DAQ (Legacy) to NI-DAQmx Using ANSI C and NI LabWindows™/CVI
Transition from Traditional NI-DAQ(Legacy) to NI-DAQmx using ANSI C and NI LabWindows™/CVI: Part Two
Transition from Traditional NI-DAQ (Legacy) to NI-DAQmx using ANSI C and LabWindows/CVI: Part Three
Transition from Traditional NI-DAQ (Legacy) to NI-DAQmx using ANSI C and LabWindows/CVI: Part Four
