09-19-2009 12:16 PM
09-21-2009 01:58 PM
Hi tcumech,
There are a lot of things to consider here so I'm going to try to break it down to pretty simple pieces.
First, be aware that our motor controllers work best with LabVIEW. We do have the ability to call functions on the controller from C, so you may be able to call those functions from other dev environments. However, it may not be ideal.
Second, the key with a motor is the drive. We need to have a drive that will run the motor, then we can worry about which motor controller is right for it. Please let me know what drive you plan on using and we can consider controller options.
